560 Farmall, 282 cylinder head
brian
12-13-2002 06:35:53
Hello, I am trying to locate a good cyl. head for a IHC UD 282 diesel engine out of a 560 Farmall. I'm finding them to be becoming quite rare. I heard somewhere once, that they are being remanufactured overseas. Any help on this would be appreciated. Thank you Brian Leake
Les Repair
12-13-2002 16:27:02
 Re: 560 Farmall, 282 cylinder head in reply to brian, 12-13-2002 06:35:53
When they tell you (remanufactured) they mean the cracks have been welded and new valve guides and seats have been installed. Some people seem to have a problem with this, but these remanufactured head seem to work pretty good.
RPM
12-13-2002 07:55:15
D282, was used in 656/706, also D236 (F460D some Construction Equip, D301, 715 early combine, more Construction, would all have interchangeable heads, you will find some early heads that casting number begins with 278 will work that were smaller valves, this was only on 460/560, the correct head should have casting 323771 or 3R series, match your valve diameters. I am not aware of any replacement castings other than original, there is still a lot of used out there.
