Torque problem
Bryce Andreasen
12-15-2002 19:50:09
I finaly got my 400 farmall after waiting two weeks. I went out on the highway, turned around and was getting back on after turning around on gravel road, and had to wait for a car so i put it in fifth gear with the torque back but it made a screaching noise and didn't move. Later on, I hooked on to our box scraper and put it on the ground. Put it in first gear with the torque ahead and started to pull. When it started to pull hard, i pulled it back and made the screaching noise again. But i put the clutch in and let it back out and finaly started moving again. I belive it is the overriding clutch in the TA that sometimes doesn't catch. I want to fix this so when I tractor pull i don't sitt half way down the track at a hault!
Doug C. TEX
12-16-2002 05:19:22
 Re: torque problem in reply to Bryce Andreasen, 12-15-2002 19:50:09
My 350 sat for over 8 years when I got ready to use it had same happen to it. got manuel and adj.to spec. Been working good for past 4 years. With luck proper adj. will get you going too
TA is out
12-15-2002 20:08:38
Your torque amplifier is out on the low side. The problem most likely is with the ramp and rollers. If it pulls fine in high range (direct) then your TA clutch is fine.
Ron in Tucson, AZ
12-15-2002 20:28:46
 Re: Re: torque problem in reply to TA is out, 12-15-2002 20:08:38
also you can not use the TA in 5th gear and a good chance it is also weak LOL Ron
