Farmall B
Bill Matetzschk
12-18-2002 16:59:55
I am in processing of obtaining a B and it does not have any hydraulics.
How can I add and will it convert to a three point setup?
Also it has been set up for propane. What do I have to do to convert back. The gas tank is still on tractor.
Thanks,
Bill
Haas
12-19-2002 03:50:49
 Re: Farmall B in reply to Bill Matetzschk, 12-18-2002 16:59:55
I suppose you could put a 3 pt hitch on a B, but it will be complicated because the final drives and hitch points are so wide. I've never seen a 3 pt kit for a B. As to hydraulics, there are pumps available that can be put on the PTO, or you can rig one to run off the generator belt. By the time you do all this, you will have a lot of expense. I think better, easier and cheaper to find a tractor that has the hydraulics already.
