140- oil Bath air cleaner
Avery
12-23-2002 08:30:08
Aren't you better off using a non-detergent oil in the oil cup so the particles will settle better or does it not really matter? Also what kinda luck anybody had with Lucas additives? Tkanks, Merry Christmas
IH Bill
12-23-2002 17:55:48
 Re: 140- oil Bath air cleaner in reply to Avery, 12-23-2002 08:30:08
it is best to use the same oil that you use in the engine and that should be Case-IH straight grade low ash oil preferred. The key is keep it clean by changing it more frequently in dirty conditions.
Hugh MacKay
12-23-2002 18:12:15
 Re: Re: 140- oil Bath air cleaner in reply to IH Bill, 12-23-2002 17:55:48
Change it regularly, and if in dusty conditions change daily. I have been involved in farming operations were we changed the oil in air cleaner daily.
CNKS
12-23-2002 13:47:55
Don't think it makes any difference -- the particles are compacted in the bottom of the cup by centrifugal force, so they do more than just settle.
Jerry A.
12-23-2002 11:21:21
I've used the Lucas power steering stop leak with success. It seemed to help with the steering trouble I was having with my old Volvo.
Dan Kelley
12-23-2002 09:03:11
Doesn't matter. The detergent is really to keep the sludge from forming (and to help remove old sludge) inside an engine. It should have virtually no effect on your engine.
Just a tid-bit. When I first got my M, there was a ton of build-up of dust inside the intake pipe. I bought a hefty plastic toilet brush to clean all that out. So, don't take anything for granted.
