Super M problems
Adam Stratton
12-23-2002 21:09:37
I need a replacement seal for the live hydrolic pump on my Super M, none of the local dealers, or auto parts stores have one. Do any of you know of any good place i could get one online?? any help would be appreciated.
thanks
Bob in SE Nebraska
12-24-2002 05:22:38
 Re: Super M problems in reply to Adam Stratton, 12-23-2002 21:09:37
Call Ken Updike at Carter and Gruenwald, I am sure he can get the seal. 608.455.2411
Larry Martin
12-24-2002 05:07:56
I personally have never had one apart. However, if it is what you may call a "regular" seal, that being of a common design, you should be able to measure it with a calipers and buy a replacement seal. I live in Madison, WI and there is a company called Motion Idustries that has not failed me yet.
Dr.Evil
12-24-2002 06:28:33
 Re: Re: Super M problems in reply to Larry Martin, 12-24-2002 05:07:56
HA... I only live about 8 miles from Motion Ind. in Madison. They can probably get a seal for You. And Motion Industries is a national seal/bearing distributor with outlets in every major city. But in this area I'd try either Carl Statz or Carter & Gruenwald first. And get the right part the first time & be home installing it an hour later! In any case, take the old seal with You to make sure You get the right part.
