IH 300 utility hydraulics
Brett
12-26-2002 14:11:11
when using 2 point hitch with the valve in the double acting position everything works fine. when i put it in single position i have power down and nothing up . is this right I would have thought It would lift and down would be a float
Les Repair
12-26-2002 16:22:43
 Re: IH 300 utility hydraulics in reply to Brett, 12-26-2002 14:11:11
Somewhere earlier the hoses were disconnected and put on backwards. Setting in the float position still wouldn't let the drawbar go down because there is a check valve in the line,and you need hyd pressure to release the valve.
