Super C
Bill L Md
12-29-2002 05:55:28
Don't know the year.Fellow tells me it's a Super C . I'm going to do more snooping around take a better look, no decals bad repaint,runs good, good rubber, hyd. work, two bottom plow. what's it worth?????
Bill L Md
12-29-2002 14:16:37
 Re: Super C in reply to Bill L Md, 12-29-2002 05:55:28
Thanks y'all,I was hoping to get this tractor for under 1,000.He told me to make him an offer.Needs some wiring going to start at 600.00
BIG JOHN
12-29-2002 14:05:57
As far as worth goes: I think that I stole this one. Super C w/front end loader & 5' trail mower, 4 great tires & rims, 12 volt conversion, fenders, runs good no smoke, plus a C tractor for parts w/good rear tires & rims - $1500.
SAm in NS
12-29-2002 13:18:36
Can't help on the value but there are a couple of quick checks that might help to confirm it as a Super. The Supers have waterpumps, a 2" gap between the touch control and the gas tank, an extra 2" segment at the bottom of the middle section of the grill. There are a few other things as well. The serial No. plate should be on the right hand side of the box the seat is bolted to. All the main components have codes cast into them. They are given as month*day*year, the month and day are numbers, the year is a letter (X is 52, Y is 53, and Z is 54) and the asterisks look like screw heads. Hope this helps. SAm in NS
Joe in PA
12-29-2002 08:26:18
My 54 super C came with a front homemade dozer blade, 2 bottom plows, chains, and a couple of odds and ends. The paint is fair same with the tires, wide front (very welded). Runs good, hydro is Ok, getting weak on one side. I got it for $1800
H Fan
12-30-2002 16:33:18
 Re: Re: Super C in reply to Joe in PA, 12-29-2002 08:26:18
Joe,
This Super C come from New Bethlehem PA?
Sounds like one I looked at about 3 years ago.
