Super C Trans Lube
Achodges1
01-03-2003 22:14:09
Just bought my first farmall.(My other toy is a moline.)This is the first Super C I have seen. Not at all like the H I drove as a kid. It has Hy-tran in the trans and final drive right now and is leaking at every seal. I found the drain plug and the fill plug but I cannot find a level plug unless it is on the side of the PTO. Should I use 90-W or 140-W in the trans? This is also the first tractor I have seen without a dipstick. How do I check the engine oil?
SAm in NS
01-04-2003 04:57:14
 Re: Super C Trans Lube in reply to Achodges1, 01-03-2003 22:14:09
For oil in the transmission you are probably best off with either the 90wt or the 140wt. If it gets really cold where you live or the transmission is nice and quiet then I would go with the 90wt. Otherwise try the 140wt, it shouldn't harm anything. I think the level plug is on the right hand side of the transmission back towards the PTO. It should just be a small pipe plug. To check the engine oil; on the left hand side of the oil pan there is a pair of petcocks. The oil should flow out of the bottom one but not the top one. Add oil through the breather on top of the valve rocker cover. Hope this helps. SAm in NS
achodges1
01-04-2003 18:28:57
 Re: Re: Super C Trans Lube in reply to ScottyNY, 01-04-2003 04:54:22
Thanks for the info. Hope to have a manual soon.Since it doesn't get that cold here I will go with the 140W.
