Bigdog need more advice on hyd
Bill L Md
01-04-2003 14:20:07
Bigdog, did what you advised me to do on the cub hyd,after filling, had alot of water run out of the system when running the hyd system to get the air out,but my real question is what goes in the big hole directly in the top of the resevoir at the 11 oclock position to the fill plug,it is cast into the top of the resevoir and is flanged down maybe 1/8 or 1/16 of an inch. Something must go in there to keep the moisture out.Plow will almost come up by itself but I have to plug that hole.
Bigdog
01-04-2003 16:31:36
 Re: Bigdog need more advice on hyd in reply to Bill L Md, 01-04-2003 14:20:07
The hole in the top of the reservoir is for an expansion plug. E-mail me at the addy above and I'll e-mail you a copy of the touch control manual.
Bill L Md
01-04-2003 16:44:44
 Re: Re: Bigdog need more advice on hyd in reply to Bigdog, 01-04-2003 16:31:36
Thanks, e-mail on the way
