Widening your 806 front end
Bill L Md
01-04-2003 17:08:15
How did the guy widening out the front end on his 806 856 ???? make out, all the sugestions that were on here I'm kind of curious, what worked or what didn't work.I would imagine you post 12/31/02
Larry B
01-06-2003 05:32:34
 Re: widening your 806 front end in reply to Bill L Md, 01-04-2003 17:08:15
I guess I the one your refering to, I still have had no luck. I have tryed heat, pulling, hammering, even tryed to pull apart with another tractor. I guess if I want the front out bad enough, I'll buy another front axle assambly. A friend I know has the same problem on his 1086. He's trying running with the clamps loose and replaced the pins thru the axle tubes with 3/8 bolts.
Bill L Md
01-06-2003 10:58:58
 Re: Re: widening your 806 front end in reply to Larry B, 01-06-2003 05:32:34
Larry , one other thing you might want to try, olive oil,yes olive oil, and old guy told me about it in freeing up stuck pistons ,I have used it seams to work real well.Get a bottle and get it into the tubs let it soak it might just work
