Plow
Arnold E. Mille
01-05-2003 12:32:08
Will a mounted plow for a Farmall A fit on a Farmall Cub? What is the difference between the plows? Does someone have model #s of each and is the # stamped on the respective plows. A friend has a plow he will give me, we believe it might be for an A, not sure. I have a cub.
Appreciate any info,
ThanX,
AEM
Haas
01-05-2003 17:03:03
 Re: Plow in reply to Arnold E. Miller, 01-05-2003 12:32:08
The plow for the A and the Cub are not interchangeable. The beam on the A plow is longer and heavier, as well as other differences. The bolt holes for mounting to the drawbar may be different too. There were a number of different plows available for both the A and the Cub.
SAm in NS
01-05-2003 12:40:25
I'm not entirely sure but I think the plow for the A is bigger than the one for the cub. It may work, it would depend on your soil and how you used it. Hope this helps. SAm in NS
terry clubb
01-05-2003 13:41:31
 Re: Re: Plow in reply to SAm in NS, 01-05-2003 12:40:25
the plows for for the A SuperA and cub will not work from one to the other. the cub plow beam has a slight twist in it where it attaches to drawbar' also it has a handle that mounts to the right final drive and drawbar is turned to front of tractor has to swivel any questions email terry clubb hope this helps
