Front Crank Seal Removal Super A
Brian
01-07-2003 14:12:27
I was wondering how to remove the front crank seal from the cover plate. I have what I think is the original one still in. It looks like there may be a lip on the cover that keeps the seal in, if there is do I have to bend it back to get the old seal out ?
What have you guys done to get them out ?
I don't have a press.
Thanks
Brian
geoff gauger
01-07-2003 14:36:58
 Re: Front Crank Seal Removal Super A in reply to Brian, 01-07-2003 14:12:27
It's just a press fit, no lip or retainer. I assume you have the cover off, the seal get's pressed out the back. A screwdriver is all it takes to get the old one out.
Jon Mirgon
01-07-2003 18:02:55
 Re: Re: Front Crank Seal Removal Super A in reply to geoff gauger, 01-07-2003 14:36:58
Geoff,
Your front seal is just a press fit, take the front cover off and support the cover with some 4x4's underneath and use a screwdriver and a hammer and drive the seal out from the front, clean the inside of the cover good, and then carefully drive the new seal in from the back of the cover, when I install mine, after they are drove in, i use some Indian head, head gasket sealer on the back side, use the sealer on the metal surface of the cover to the metal surface of the seal.
EZ
01-07-2003 19:00:09
 Re: Re: Re: Front Crank Seal Removal Super A in reply to Jon Mirgon, 01-07-2003 18:02:55
You might want to have an eye,
my '44A had the seal "soldered" in place.
This is the front seal on the timing cover you are talking about?
We had to grind the solder out to remove the old seal, new seal is in, and no leaks.
