Live Hydraulic Power Unit for 1944 M
Brad Kimball
01-07-2003 20:05:09
How will the addition of a hydraulic power unit to my M benifit the utility of the tractor? What else will I be able to do? Where does it fit on the tractor. Will it use 2 hoses or cylinders? Any information is appreciated greatly
Dan
01-07-2003 22:01:14
 Re: Live Hydraulic Power Unit for 1944 M in reply to Brad Kimball, 01-07-2003 20:05:09
The addition will be a benefit if you use the hydraulics a good deal. If you add a 3 point you can still lift when the clutch is in for example. With a loader it will lift when you have the clutch in. Definite benefit. If you don't use the hydraulics that much you might as well not add it. With the live unit you can use double acting cylinders, with an added valve. The unit fits in front of the mag/distributor. You may need a different plate ahead of it for mounting, I'm not sure.
