F-12
Adam Bronson
01-08-2003 08:42:49
Anyone ever seen an F-12 with hydrolics. Its all cast under the seat with the lines running up the left side. It also has a rock shaft that is running through the assembly. any info would help.
F14
01-08-2003 09:07:51
 Re: F-12 in reply to Adam Bronson, 01-08-2003 08:42:49
That's called a Power Lift. It does not have position control, it's either up or it's down. Most commonly used for cultivators and plows.
Dead simple to work on. Pump drives off first transmission shaft and is live anytime the engine is running. Lift uses a big vane and a simple valve, most common problem is that the shaft seals are shot and it leaks by the shafts. Uses straight oil, not hydraulic oil. I use rearand weight stuff (80-90wt) in mine on that assumption that if any leaks by the pump seal it won't contaminate what's in my transmission tub. Mine works fine, but I haven't found anything to hook to it yet.
redrev
01-08-2003 09:07:16
I've had a couple through the years, but don't know anything about them, except that they both worked and leaked some.
