M live Hydraulic power unit
Brad kimball
01-08-2003 19:20:01
Found this item on Ebay #3105575505. Where does it fit on the M? What does it require to work? Hoses, Cylinders? will it work a implement off the LiftAll resivuor? Thanks for your knowledge.
Steven@nd
01-08-2003 19:38:22
 Re: M live Hydraulic power unit in reply to Brad kimball, 01-08-2003 19:20:01
First off, being it was bought at a farm auction and they don't know if it works, assume that it doesn't work.
It fits between the distributor and the timing cover and is driven from the timing gears. You will need to modify the belly pump reservoir to make it work with this pump or add another reservoir. Also you will need a 2-way valve and hoses. Expect to have over $200 in the hoses, valve, and reservoir by the time your done.
Stan(VA).
01-09-2003 05:39:15
 Re: Re: M live Hydraulic power unit in reply to Steven@nd, 01-08-2003 19:38:22
Also,
unless your M is after serial number 282xxx (don't remember full number) then you will have to replace the front timing cover with one from a SuperM/400/450 as the bolts will not line up.
Stan(VA).
RON POLK
01-08-2003 19:31:15
I USED 450 HYDRAHLIC SYSTEM ON OUR SUPER M MOST BOLTS IN PLACE
Dick Davis
01-09-2003 03:19:30
 Re: Re: M live Hydraulic power unit in reply to RON POLK, 01-08-2003 19:31:15
Check archives, I believe the distributer drive gears need to be replaced when adding a live hydraulic pump?
