Bob M, light dimming coil.
Bob
01-12-2003 14:57:54
Bob, I changed my cub to 12v as per your excellent diagram. Now that I installed my 12v lights the dimmer coil behind the light switch glows bright red while in the dimming position. I have never had lights before so I don't know if this is correct. I like the dimmed lights but I think I have to change the coil for a modern resistor but I don't know what size. Thank you, Bob
Bob M
01-12-2003 17:28:12
 Re: Bob M, light dimming coil. in reply to Bob, 01-12-2003 14:57:54
Bob - You certain the light switch is wired up correctly? The original dimming coil should run COOLER on a 12 volt conversion with 12 volt lamps installed.
Another possibility: Are the 12 volt lamps "standard" tractor seal beams, or have you substituted higher wattage lamps?? (Higher watt lamps draw more current and will make the dimmer coil run hot).
With the motor off, what does the ammeter read with the lights in both "B" and "D" positions? Post back and we'll go from there! ...Bob M
