FARMALL 460 HYDRAULICS and T/A
big red 1
01-15-2003 15:32:26
IM LOOKING at purchasing a 460 for a loader rig and would like to be able to use the fast hitch on the back.It has no loader on it now but when I hit the touch levers it wont raise the hitch at all i feel pressure thru the lines and pressure to the line on the fast hitch cylinder but no action,help me guys whats going on.
also the the t/a lower side is out when i pull it back i get grinding,clutch and transmission seem ok,what will this take time and money
please advise thanks
big red 1
ernot
01-18-2003 18:35:06
 Re: FARMALL 460 HYDRAULICS and T/A in reply to big red 1, 01-15-2003 15:32:26
sprags are gone in torque..TA is shot or on way out.
ernot
01-18-2003 18:32:32
It may be that some how the hydraulic hoses got switched. Some 460's had fast hitch hydraulic hoses that used quick couplers beside where the head light pipes atttached to the tractor. It sounds stupid, but think the loader lines and the fast hitch lines are crossed.
Chuck
01-16-2003 15:53:14
If you feel pressure on hydralic lines to fast hitch cylinder but the hitch won't raise there is a good chance that there is a mechanical problem in the hitch itself. Check to see if there are any bolts or pins working out and locking up the hitch.
Red Man
01-15-2003 18:30:49
If it has the 2 or 3 lever set-up, the right hand lever should raise the hitch, the middle lever is for rear remote, and left lever is for front remote.
Ben in KY
01-15-2003 17:42:21
If the TA is out it will take both time and money or more money if you hire someone else. Not sure on the lift problem. Do a search on this board for TA. A lot of information there.
