Belt pulley housing on an M
Andy in Ohio
01-15-2003 19:37:41
Can anyone tell me how much and what wt. of oil to put in an "M" belt pulley gear housing? Thanks for the info Andy
The Red
01-16-2003 02:48:24
 Re: belt pulley housing on an M in reply to Andy in Ohio, 01-15-2003 19:37:41
Andy the belt pulley housing is fed 90W by the transmission slinging oil up into the unit. If you had the pulley shaft out to replace bearings, then I recommend you pour 1/2 quart of 90W in the filler hole on top of the unit so there is oil in the lower section of the pulley housing next to the pulley plate.
