Wide front off 656 to farmall 460
big red 1
01-19-2003 09:04:35
will an international wide front off a 656 bolt right to a farmall 460.
If it will not please tell me wh, im learning
thanks
Duane NC OH
01-20-2003 05:48:35
 Re: wide front off 656 to farmall 460 in reply to big red 1, 01-19-2003 09:04:35
i put a 656 wide front end on my 560.
paid $750 for it and it bolted right on. just bolt everything loose to start with. its a tight fit. tractor works great.
good luck!
Duane
Harold H
01-19-2003 15:22:15
If it is from a Farmall 656 yes, if it is from a International 656 no, that is a complete different design.
Harold H
Hugh MacKay
01-19-2003 12:10:50
Should bolt right up with one possible exception, where it bolts to frame rails may be a bit different width. May need some modification. Some tractors are wider on frame rails than others. The rest of the holes will be exact.
