140 international hydraulics
bill poindexter
01-23-2003 09:48:35
1 have a 140 international. i changed the fluids but the rear hydraulic will not stay up. i used Hytran fluid and tried to get the air out as the manuel says. for some reason the unit is catching air. when the rear lift starts going dowm if i undo the nut and bleed air it is fine for awhilebut the rear lift will start droping in awhile. what is wrong?
Jack
01-23-2003 16:37:42
 Re: 140 international hydraulics in reply to bill poindexter, 01-23-2003 09:48:35
Sounds like you have a problem with the valve body. Take pressure readings at the fittings provided. Do you have any external leaks?
Gary Holtman
01-23-2003 17:50:39
 Re: Re: 140 international hydraulics in reply to Jack, 01-23-2003 16:37:42
Pull the unit off the tractor,pull the head.Inside are two valves on each side of center,one set for front, the otherfor rear. Replace the plastic parts of these valves.The control levers have probably been out of adj, making the valves jump.The big valve in the center is the pressure control valve. Pull it out by thetit in the center and check the plastic in the back.It should NOT have an indentation or hole in the center. While you're in there, change the "O" rings on the control rods. They slip right out once you disconnect them.
