Farmall FastHitch Plow
BobG
01-25-2003 18:42:15
Would like to know if anyone knows where a 2 bottom 12" or 14" fasthitch plow for 2 1/2 inch prongs (for a Farmall 230) might be found. I'm lookin'. Thanks, BobG
RayP(MI)
01-26-2003 12:33:46
 Re: Farmall FastHitch Plow in reply to BobG, 01-25-2003 18:42:15
Your other option is to convert to 3point, and then the problem of finding plows and other impliments becomes significantly easier. worksaver.com would be a good site to start. Check out their HK326. I have one on a Farmall 200, and it works pretty well. The only problem of major importance is that the impliments will have to be the right width to fit the width of your 2pt hitch. I ended up shimming the hitch pins in some to get the right width.
David B
01-26-2003 06:07:44
Noticed Glens picture of fast hitch plows and they aren't equiped with disc cutters (or coulters). I never used a plow with out the cutters, is that the norm in some areas?
Randy
01-26-2003 05:32:10
I have one @ $285 in good condition that came off a Farmall 200. Located central Ohio. Thanks
steve450
01-25-2003 22:09:38
I have a set that need some minor work. I am located in central pa. Drop me an email if interested.
bill b va
01-26-2003 05:11:48
 Re: Re: Farmall FastHitch Plow in reply to Glenn(WV), 01-25-2003 19:08:17
i have one of these and have been trying to identify it... looks just like the picture ...appears to be adjustable for 14 or 16 ... would like to know what i have so i can buy parts... what does supera mean in the ad below the picture . the dummies at TSC were no help at all ..... ..... . thanks.. bill
dick
01-26-2003 08:24:07
 Re: Re: Re: Farmall FastHitch Plow in reply to bill b va, 01-26-2003 05:11:48
The "supera" probably means that the prongs are 2-1/2". These are the lighter-duty size; larger tractors/implements had the 3" prongs.
You might try Lee Grady at the State Historical Society of Wisconsin (608/264-6400) for help with the identity of your plow. They maintain the IH Company archives.
Good luck finding parts. Many of these Fast Hitch plows used the "Plow Chief" bottoms which were replaced with the "Super Chief" bottom. The latter has a one-piece plowshare versus the plow point used in front of the share on the Plow Chief bottom. There aren't many sources for Plow Chief parts left excepting Case IH; finding parts for the left-hand bottoms (for a roll-over or "switch" plow) at any price is extremely chancy.
BobG
01-25-2003 19:13:03
Thanks Glenn, That was quick! Oh, and you're right, they are kinda pricey, huh? BobG
Farmall-Nut
01-25-2003 19:22:13
 Re: Re: Re: Farmall FastHitch Plow in reply to BobG, 01-25-2003 19:13:03
Dont get discouraged I just found a 2 bottom for my Super C for 100.00 and have seen two for 250.00 recently!
