New Regulator on an H
Ben
01-27-2003 20:44:20
Can someone explain to me the proper procedure for polorizing a new voltage regulator on a 6 volt positive ground H.
Chris in SeMo
01-27-2003 21:02:50
 Re: New Regulator on an H in reply to Ben, 01-27-2003 20:44:20
Yeah Ben,Just momentarily connect the BAT terminal
on the regulator to the the A terminal on the generator.You need to do it with the engine Not running.Should get 1 quick spark and your done.Hope this helps,Chris in SeMo.
john
01-28-2003 14:56:26
 Re: Re: New Regulator on an H in reply to Chris in SeMo, 01-27-2003 21:02:50
How often do you have to do this?
Chris in SeMo.
01-28-2003 17:20:34
 Re: Re: Re: New Regulator on an H in reply to john, 01-28-2003 14:56:26
One time will be all you need to do it John,But I
have had to polarize them again after the battery
was disconnected for any reason,but not every time.Hope this helps,Chris in SeMo.
