686 TA
Aces
01-28-2003 04:55:28
I have not worked on a 686 TA but from what you said the PTO drive gears must be a little different than the older models if the PTO shaft is one long and that is why you pulled the PTO then the PTO driven gear should drop out the bottom of the TA housing and let the drive shaft out the front. Did not have to do that on the older tractors SMTA through 666.
