Ammeter reading??
bronco
09-03-1999 18:48:11
On my Syper A, I'm getting a fluctuating reading on the ammeter. What could be the cause ??? The needle constantly jumps back and forth, however it is always on the charge side.
ltf in nc
09-04-1999 06:08:54
 Re: Ammeter reading?? in reply to bronco, 09-03-1999 18:48:11
You probably do not have a problem. Most of the needle movement comes from the inability of the gauge to dampen. Expensive gauges usually have this feature enhanced in their design. The range or scale on the gauge also impacts the degreee of fluctuation.
Village Blacksmith
09-03-1999 19:59:36
I would check the brushes in the generator for excessive arcing. Then check the contacts in the regulator for excessive arcing. Check for loose connections in the wires from generator to regulator and to ammeter.
