Shifting repair
806 owner
01-30-2003 18:20:49
Has any one ever repaired there shifting in a '06 series tractor with a kit from Wenz Service Inc out of Nebaska. I am considering trying one of these kit. My 806 has terrible shifting. If any one has any other sugestions on how to fix it they would be appreciated.
Mark
02-02-2003 06:52:54
 Re: shifting repair in reply to 806 owner, 01-30-2003 18:20:49
I bought one of these for the 1206
If you have access to a machine shop you could do this yourself
He has an excellent idea regarding the change of the stroke on the cam
for the 600 it was worth it and it works great
half the battle it removeing ALL the slop and play in the yolks and pins and the cover
Jim
01-31-2003 07:15:45
I have redone several of his so called fixes. he has one good idea on the fix. In my opinion put the 56 series shift on instead of his over priced kit.. It will cost only a little more and it will increase the value of your tractor.
Jake F
01-30-2003 22:23:54
A lot of them were converted to the 56 style. If you are going to use it as a work tractor that is an option. Just don't throw the original stuff away. Otherwise just start replacing any loose pins and bushings. While your under the deck check that all the pins in the park brake linkage still have there cotter pins. Jake
