How much does my H weigh??
Bob
02-10-2003 18:18:57
Could someone tell me how much my 1942 Farmall H weighs? It has cut off steel wheels with rims welded on and loaded tires. Does NOT have a electric start, PTO or a belly pump. Any idea how much it weighs? Any thoughts would be appreciated! Thanks Bob
Bob
02-11-2003 12:33:04
 Re: How much does my H weigh?? in reply to Bob, 02-10-2003 18:18:57
Thanks for info! My tractor does not have any weights but has both rear tires loaded. Any idea how much extra weight the loaded tires add? Thanks Bob
rustyfarmall
02-11-2003 12:27:23
I have a similar H cutdown rears. no fluid does have starter, pto, belly pump. last summer at a local pull it weighed in at 3,750 with me on it 235# I think I had about half tank of gas
Lowell J Schauer
02-11-2003 06:13:58
Our club here in Phoenix just completed antique tractor pulls this past weekend and the H's were in the 4200# to 4400# range. Also in the same range were the 1947-1952 John deere "B"s.
CNKS
02-10-2003 18:45:36
3725, with the wheels for rubber tires. Your wheels are probably lighter, unless someone found a way to add weights to them. Add the weight for the calcium chloride. Starter and pto don't weigh much, however belly pump is heavy. Someone else will have to give you an estimate on the gallons in each tire. You are probably going to be about 4000 lbs with the weighted tires.
The Tractor Doctor
02-10-2003 18:26:58
Hi...
According to my books your "H" weighs 5550 lbs
Mike ISW
02-11-2003 03:39:04
 Re: Re: How much does my H weigh?? in reply to The Tractor Doctor, 02-10-2003 18:26:58
5550 is way high. scaled my H last summer. Regular rear wheels with 1 wieght each. No belly pump and me (180lbs) on it and it was 4200 lbs.
CNKS
02-11-2003 07:37:03
 Re: Re: Re: How much does my H weigh?? in reply to Mike ISW, 02-11-2003 03:39:04
Yup, take Guy Fay's 3725, two 140 lb weights plus your 180 and you get 4185 lbs -- pretty close.
