Value of IH 560 Diesil
Bob Mn.
09-06-1999 11:55:27
Am looking at a 560 with straight tin and 6 ft. bucket in good shape with power down, tires have good tread but are bad with age.Are they a good starter in -0 weather.Thanks for any input.
bill
09-18-1999 21:19:57
 Re: Value of IH 560 Diesil in reply to Bob Mn., 09-06-1999 11:55:27
They'll start without much problem in sub zero weather as long as you use an engine heater. It helps if shedded as well as plugged in.
bob
09-06-1999 14:09:10
Hard starting in any weather.
Wayne
09-06-1999 15:21:33
 Re: Re: Value of IH 560 Diesil in reply to bob, 09-06-1999 14:09:10
Used 1 for years on my loader. Needed it to feed cattle and it always started with glow plugs and heater. This is in S.D. Where it gets way down below 0.
ro
09-07-1999 19:10:35
 Re: Re: Re: Value of IH 560 Diesil in reply to Wayne, 09-06-1999 15:21:33
Have a 560D and because of its use, I only start it every couple of weeks. In winter weather though, at least down to 10 degrees, I've never had trouble starting it. Below 10 degrees, I'm fortunate to not have to be out in the weather myself. It has the built in heater and all the glow plugs work. It starts a lot easier than my Ford Jubilee at this temperature.
It has really been a good solid tractor---I have a DuAl 325 Loader on it.
AJ560D
09-08-1999 09:41:43
 Re: Re: Re: Re: Value of IH 560 Diesil in reply to ro, 09-07-1999 19:10:35
We just got a 560D this spring. Know recent history. Was overhauled and new TA 6 years ago but was never realy used. Tricycle front end. Straight tin,good solid tractor.Tires good.Paid $2,800.00.
sjk
02-16-2000 15:45:33
 Re: Re: Re: Re: Re: Value of IH 560 Diesil in reply to AJ560D, 09-08-1999 09:41:43
I have the privilage of owning two 560's the first was a diesel the 282, we never had much trouble with it. This tractor was mint it had the factory wide front very good paint, good tires, ran very good and had a set of 3-14 fast hitch plows. I sold this tractor in the late 80's and got 4200.00 dollars for it. In 1995 I bought a 560 gas I paid 3200.00 dollars for it had good tires, paint, factory wide front, new clutch and ran good. So here's an idea of what I sold and bought mine for.
