10-20 paint
Bill
02-12-2003 19:08:59
Does anybody know the official shade of gray used on the 10-20s? Mine is a 1924. I've seen everything from very light gray to battleship gray to a mostly blue gray.
ontwill
02-13-2003 18:19:33
 Re: 10-20 paint in reply to Bill, 02-12-2003 19:08:59
Bill,the color is Centuri 27625 as Tom said.If you go to UAP or NAPA automotive they can cross the numbers for you.On mt gallon can it reads [27625A Charcoal], in Canada the gallon cost me $150.00 all premixed with hardener and lacquer blend . I had it painted with 3 coats and it took just under three quarts.I got two 10-20's one is a 1931 the other is a 1937 which is [HI RED].They changed the colors of everything in nov,1 1936. Good Luck.WILL
Tom
02-13-2003 04:38:09
Bill,
I have a 1926 15-30, underneath the tractor and pressed between two pieces of sheet metal I found a dark grey. I used Dupont Centauri 27625. it matched perfectly. I have seen others painted a lighter shade.
Tom
Jeff
02-13-2003 18:20:36
 Re: Re: 10-20 paint in reply to Tom, 02-13-2003 04:38:09
I agree with Bill every McDeering and farmall are the dark gray they look real good the lighter looks faded and does not do the tractor any justice
