Gear Oil
Avery
02-14-2003 04:19:18
Anybody ever used any Super Tech Products, such as Gear oil, or there motor oils? If so what's your opinion about it. Know it costs a little less but is it comparable in quality?...
Delbert
02-14-2003 15:51:09
 Re: Gear Oil in reply to Avery, 02-14-2003 04:19:18
I have used it in motors that used oil and thouht it reduced oil consumption. Will help clean tem up inside. Just my 1.00. 2.98.
earlschieb
02-14-2003 10:04:27
I use Super Tech products in everything that I own, have had great luck wth it.
Farmall Ed
02-14-2003 06:46:22
Avery I have been using Super Tech 3owt detergent motor oil in my Hs the last couple of years,I have been satisfied with it,but my tractors are not used heavy just a day every week or so.I dont know how it might hold up under heavy use,but some on the board will know. ED
dhermesc
02-14-2003 06:09:42
I tend to use the motor oil in equipment that gets the oil changed due to age more then hours of use. As for the gear oil, its in my IH 350, the transmission and rear end of my '64 F250, and '96 F150. It was a very noticable improvement in the old F250 and the 350, both still had the original fluid by the looks of what drained out. Remember, even the cheapest oils are more highly refined then what was put out in the 30s, 40s, 50s, 60s and early 70s. Super Tech is an improvement over the original fluids used on this old farm equipment.
