Up past my Knees below the Mason Dixon
Bill L Md
02-16-2003 14:54:47
Just got back in from plowing if you can call it that,bustin open is more like it.My snow blower is not going to cut it tonight up above my knee caps and I'm 6ft.17:55 and still snowing been at it since 02:00,I missed most of the abreviated race did see the 1st 40 laps before I went out. MW had a strong car still would of liked to see it go green for 500.Were payin for that drought now,Gov just declaired marshal law of some kind if your caught on the road and your not an emergency care provider $1'000.00 fine
farmnut
02-16-2003 20:16:14
 Re: Up past my Knees below the Mason Dixon in reply to Bill L Md, 02-16-2003 14:54:47
bill have relation in garret county md 38 inches there and still coming down.
Mike
02-16-2003 19:54:34
Bill,
I have the same complaint and I'm above the MD line about 60 miles, why can't you guys just keep the fun to yourselves. You know there are things other than plowin' snow I'd like to do :o)
Mike
Brian S.
02-16-2003 18:02:05
James, Sorry to hear about the snow! We're kinda used to it here but you folk's aren't supposed to get that much in your neck of the wood's.We've been below 0 for most of the winter and we have deep, deep snow.I myself am gettin kind of fed up with it.Could'nt get the 300 started today so had to drag log's to the house with my Ranger pickup.We drag the wood close and cut and split it by the back door so we don't have to go far to get it.Keep smilin', Brian S.
James Williams
02-16-2003 15:12:50
BILL WHERE ARE YOU LOCATED in MD. Ive read a lot of your messages. were you the one who answered a guestion about a SC light switch terminals. I have removed the switch from my H, there is 2 terminals on the bottom of the switch that goes to the alt.can you tell me where each wire goes
Jimmy Williams
Charlestown WV
Bill L Md
02-16-2003 16:20:37
 Re: Re: Up past my Knees below the Mason Dixon in reply to James Williams, 02-16-2003 15:12:50
James,I don't think I was the one don't recall,if you had a gen. I could go out and get my book and look it up for you but my book dosn't have alt hookups in it.I live about 1 1/2 hours away from you,in Owingsmills.
James Williams
02-16-2003 16:50:12
 Re: Re: Re: Up past my Knees below the Mason Dixon in reply to Bill L Md, 02-16-2003 16:20:37
Thanks for writing back. My H has 2 wires going to the alt. One to the L terminal, and the other to the BAT. termanial on the regulator, on the other end at the light switch there is 2 terminals one has what looks like a resistor wire and the other is just a plan end, however looks like both terminals are connected to each other.PS I live in town on a 1/8 ac lot and own 6 tractors,I DONT UNDERSTANDED TO 30 fergusion,Farmall 200, 2-Hs farmall 340, F12
Jim
02-16-2003 17:17:16
 Re: Re: Re: Re: Up past my Knees below the Mason Dixon in reply to James Williams, 02-16-2003 16:50:12
Depends how old your H is, the older ones had a gen with a cut out and later ones had a regulator.
If your switch has four postions, Low charge, high
charge, dim lights and bright lights along with a working rear light. The two wires, one went to the cut out and one to the F terminal on the gen. On switch end wire from cut out went to the ampmeter & other from F terminal went to the resistor. Giving you H/L charging. Working on a H last week with same system.
