Cub
Regular ,Lowboy Difference ???
230,H,M
02-20-2003 15:24:17
What is the difference between a "Regular Cub and a "Lowboy Cub"?
230,H,M
02-21-2003 15:44:41
 Re: Cub - Regular ,Lowboy Difference ??? in reply to 230,H,M, 02-20-2003 15:24:17
Thank you all for the info. Now I know.
BIG JOHN
02-20-2003 17:48:39
The Cub's are badged "FARMALL". The Lo-Boy's are badged "INTERNATIONAL". The Lo-Boy's wheelbase is 7 1/4" shorter and the height is 7 1/2" shorter. All Lo-Boy's have the under the axel muffler. Standard tires on a Cub are 300 x 12" fronts and 600 x 24" rears, on the Lo-Boy they are 400 x 12" fronts and 700 x 24" rears.
If the front axel is lower that the top of the front tires, it's a Lo-Boy.
HOOPE THIS HELPS!!!!! !!!!!
Bus Driver
02-20-2003 16:37:14
Lots of similarities, but lots of differences also. One quick way is to look at the steering arm at each front wheel- if the arm is lower than the top of the (standard 12") front tire, it is a LoBoy. If the arm is higher than the tire, it is a (regular) Cub. This method works for those instances where no other tractor is available for comparison.
Leroy
02-20-2003 16:52:27
 Re: Re: Cub - Regular ,Lowboy Difference ??? in reply to Bus Driver, 02-20-2003 16:37:14
Which is the most desirable or most valuable? I just saw a Cub Low-Boy sell at an auction for $2700.00 with an almost new 48" belly mower.
Bus Driver
02-20-2003 17:01:43
 Re: Re: Re: Cub - Regular ,Lowboy Difference ??? in reply to Leroy, 02-20-2003 16:52:27
A difficult question for me to answer. The LoBoy is much more rare due to the much lower production numbers and the few years in which they were made. The LoBoy is much better for working hillsides due to low center of gravity. The regular Cub has a much larger variety of implements available. My guess is that the LoBoy probably will bring a few more $$, other things being equal.
Lowboy sits lower
02-20-2003 15:47:50
than a regular Cub.THeres one of each in the photos so you can see the visible difference.Other than dropped axles and the front end,they are pretty much the same.
Harold H
02-21-2003 07:59:14
 Re: Re: Cub - Regular ,Lowboy Difference ??? in reply to Lowboy sits lower, 02-20-2003 15:47:50
On the LowBoy the rear axle drop housings are rotated forward 90 degrees which lowers the rear of the tractor. On the regular Farmall Cub they are mounted straight down to give high clearence under the tractor rear end. Shorter front axle height already mentioned.
Harold H
