H cylinder head problem
Bob in SE Nebra
02-23-2003 14:41:53
I have a Farmall H that the cylinder head has a problem and I am not sure what I should do. The most center cylinder head stud leaked coolant between the nut and the head. I removed the head and can see where a hole has developed between the water jacket and the hole where the stud passes through the head and that allows coolant to come up and leak where it does. I am sure the only good answer is to replace the head. The tractor isn't going to be used hard at all so I thought about installing a brass washer under the nut to stop the leak. Anyone ever experienced this? Seeking advice here.
Thanks, Bob
Chuck
02-23-2003 16:45:27
 Re: H cylinder head problem in reply to Bob in SE Nebraska, 02-23-2003 14:41:53
There should be a steel sleeve in the head in that location that can be pressed out and replaced.These tractors are getting old enough that those sleeves are rusting out.
