Farmall h serial numbers
Brian Robbins
02-28-2003 13:11:12
I have A Farmall H from my father and have a good serial number to go by. I can find the serial numbers and date it to a '47 okay. My problem is that I have a X1 stamped after the serial number and haven't found out what that means. Any help?
Ted Goss
02-28-2003 13:27:23
 Re: farmall h serial numbers in reply to Brian Robbins, 02-28-2003 13:11:12
Brian: If I remember correctly, the X1 means the engine is a gas engine and the carb is jetted for normal altitudes not higher levels. Hope this helps you some
