Live pump for H
Brent
03-02-2003 17:31:14
I was wondering if anyone could tell me what kind of pump is available to convert a '49 H to live hydraulics? I used to have a Super M with a distributor pump, it worked very well. Is this available for an H? What brand, where from, and how much $? Anyone have any good/bad experiences?
Thanks!
wh
03-03-2003 10:13:13
 Re: Live pump for H in reply to Brent, 03-02-2003 17:31:14
put a "live" system on a 45 h several years ago. absolutely love it. bought a new pump from Bates Corp in indiana. got a used front cover from them as well. if i remember right it cost close to $600.00 to do it maybe a little more. added a remote hook up also. already had a 3pt hitch. to me it has been worht every penny. used the belly pump for resevior. can post pics if you need them.
Brent
03-03-2003 10:15:49
 Re: Re: Live pump for H in reply to wh, 03-03-2003 10:13:13
Where did you drive the pump from? An engine pulley? Pictures would be great.
Thanks!
wh
03-03-2003 12:48:28
 Re: Re: Re: Live pump for H in reply to Brent, 03-03-2003 10:15:49
check the link. runs off the timing gear. was not a problem to install. had to remove front end- timing gear - distributor. hope this helps. wade
Steven@nd
03-02-2003 19:56:29
Live pump from a Super H, 300, 350 plus the front timing cover and cam gear from same.
Rebuilt pump is over $400 so I'm building my own live hydraulics... Link
Brent
03-03-2003 10:18:09
 Re: Re: Live pump for H in reply to Steven@nd, 03-02-2003 19:56:29
I checked out the pictures on your website, pretty nice.
I had thought of using my belly pump to run a "live" system but wasn't sure if it would damage it leaving it running constantly, even when the spool valve it fed was closed. I see you have this as a temporary fix on your setup.
Has anyone else done this, and what potential problems may there be?
Brent
03-03-2003 04:00:24
I really didn't want to crack the belly of the tractor open so was hoping I could get some info. on a distributor type pump. Are they still available anywhere?
Steven@nd
03-03-2003 06:30:47
 Re: Re: Re: Live pump for H in reply to Brent, 03-03-2003 04:00:24
Don't have to do anything in the belly for my system. I just chose to use the belly reservoir. You can always add an external tank for oil.
Kelly C
03-03-2003 04:56:02
I think I saw a Hydralic pump for a 300 in the Classifieds on the site.
Guy
03-03-2003 11:57:10
 Re: Re: Re: Re: Live pump for H in reply to Kelly C, 03-03-2003 04:56:02
I think you might want to snag that one up for your new project!
Kelly C
03-03-2003 14:40:58
 Re: Re: Re: Re: Re: Live pump for H in reply to Guy, 03-03-2003 11:57:10
I would love to but I think I have hit my spending limmit again. I have my fingers crossed that is not one of the things I need to fix.
