300 IH Electrical Question.
Brian C
03-03-2003 09:29:42
I need to polarize an electrical system on 300 IH. I want to make sure it gets done in the correct manner. This tractor has been messed with.
It has a new gen. voltage reg. new starter and I don't want to do it wrong. It is pos. grd. Or do generator, or voltage reg. or starter have to polarized individually?
Thank You
Guy
03-03-2003 11:36:30
 Re: 300 IH Electrical Question. in reply to Brian C, 03-03-2003 09:29:42
third party image
You need to polarize the generator. Here is the directions from the owners manual.
Bob M
03-03-2003 11:25:06
Brian - Polarizing is simple to do. All you need is a short piece (about a foot) of #14 or so wire for a jumper. With everything properly hooked up - including the battery - and with the motor off, simply place the jumper between the BAT and GEN terminals at the regulator. You should see a small spark when you make the connection. When you get the spark, the system has been successfully polarized.
Brian C
03-03-2003 11:43:54
 Re: Re: 300 IH Electrical Question. in reply to Bob M, 03-03-2003 11:25:06
Thank You for your quick response Bob.
I am pretty sure I can handle that. I guess I've had a few concerns on how many people have had their hands in on this before I got it. I heard they have tried turning the battery connections around because they heard from somebody else that it wasn't a pos. grd. system.
Thanks again, I will sure give it a try.
