Farmall Regular Help....Please.
Bryan Buie
03-04-2003 13:49:33
Hi I'm just beginning the restoration of a 1930 Farmall Regular and I need some help with locating things like Rod Bearings, Cam Bushings, etc. Does anyone know of a resource that I may try? This is my 5th restoration, but I've never restored anything quite this old before. Thanks in advance!!!
dlp
03-04-2003 18:49:15
 Re: Farmall Regular Help....Please. in reply to Bryan Buie, 03-04-2003 13:49:33
I'm re-doing a W-30 engine as of now. I believe that the regular uses roller bearings on each end of the crank. If so, go to a bearing parts house & get these. They're high, so don't faint. I got my rocker bushings there also. You could probably get the other bushes while your at it. The Fordson House is a good place for parts also. I'm building a lot of the pieces myself since parts are scarce. Don't know if any of this helps, but here it is!
Ludwig
03-04-2003 17:38:30
I spect you'd want Rice Equipment. They've got about everything you could possibly need. As far as I know the engine parts should cross to an F20 as well.
Give 'em a call, (814) 226-9200.
justin
03-04-2003 16:24:33
I am currently out of rod bearings, but I do have a NOS set of cam bearings.
email for more info
Clipper
03-04-2003 14:19:11
Check out the links on the left at this site. Should be able to locate everything you need except a dwarf to paint her up for you!!
