Simple Farmall H HELP!!
ben
03-05-2003 16:24:23
i have got a 40 something farmall h i had just recently worked on it up from about 2 years of sitting, i knew it would start when i put it away, so now when i try to start it up it it doesent fire on the 1 cylender. and it shot oil from the oil bath out the air breather! i dont know how this could of happened. any help is appreaciated!!!!! !!!
Bill B
03-05-2003 18:57:37
 Re: simple Farmall H HELP!! in reply to ben, 03-05-2003 16:24:23
Take the valve cover off and observe the valves on the cylinder in question. If you have a valve stuck open, pour some penetrating oil on the valve stem and let it sit a day, then tap the end of the valve with a brass hammer lightly and see if it will pop back up where it belongs. If it is stuck, use a forked tool like a tie rod end fork to gently pry it back up where it belongs. Oil the stems of the valves and crank it again. Repeat if necessary.
TomH
03-05-2003 16:32:25
Pull the sparkplug and see if you have any compression. Sounds like the intake valve might be stuck open.
