H main bearings
Badger Bob
03-06-2003 19:42:20
I picked up a set of main bearings for my 1945 h the man i bough them from sed that they were for a H . the boxs are old and worn. they are new old stock. only numbers are on one box. thay are 357994-r11 thay are IH bearings. can somebody look it up some where? my luck they are not H bearings. thanks..
CNKS
03-07-2003 19:36:04
 Re: H main bearings in reply to Badger Bob, 03-06-2003 19:42:20
Justin is correct. They fit the H from Sn 391358 up, and are standard bearings.
JerePa
03-07-2003 18:25:31
That part number is good for Hs & 4s. They are probably standard if no other numbers following the part number.
justin
03-06-2003 20:13:56
The number you listed is for Standard Size for the late H-350. These will not work in your 45 H.
randy hall
03-06-2003 19:49:14
if the fellow said they are h bearings they probably are h bearings. but are they what you need. have you checked your crankshaft to see if you need standard or .002 under or maybe the crank is .010 or .020 or.030 under ?
B adger Bob
03-06-2003 19:58:05
 Re: Re: H main bearings in reply to randy hall, 03-06-2003 19:49:14
No i havent checked the crank. bough these dirt cheep. the guy that i bough them from has lots of junk and at times he gits confused .heck thay mite be for a Edsel.
