Super c
bret
09-08-1999 20:42:34
my question is can a wide front end and a three point hitch and a front end loader be added to a super c. is 1300.00 a good price for a 1954 super c with a narrow front end.
Tim(ny)
09-09-1999 05:39:28
 Re: super c in reply to bret, 09-08-1999 20:42:34
I had a C with a wide front and it steered much harder than my narrow front Super C. With a loader it would be even worse. If its in good shape, the price seems about right. If you want to add a loader, you'll need the remote valve assembly. Some super C's had it, some didn't, they were used for the fast hitch, among other things. It's on the right side of the reservoir on the end of the supply lines from the hydraulic pump. If you don't have this, they can be hard to get. There is a 3pt available that does not use the remotes, just rods from the lift arms. Good luck.
Brian Schmidt
09-08-1999 21:24:25
I would buy it for that if it was in good shape. You won't find sheet metal readily available. So if that is good go for it. Yes you can all all those things you want.
