Rough Running IH240 Utility
Bill Cole/Roche
03-09-2003 17:20:04
Posting my first message in this forum and looking
for advice. The 4 cylinders commpression check out
at 140-150# after warm up with#3 at 150#. #3 spark
plug fouls up with what looks like oil and blows
gas back to carb. It runs better with wire off#3
also. The other 3 cylinders foul up with carbon.
I run Champion D18s. Distributor points are pitted
and timing marks hard to read so painted area.
Engine oil is 1" above full mark. Yes I have blue
smoke coming out exhaust. I bought from a dealer
3 weeks ago and he later said (as is) Got lots of
manuals to. Questions:Carb kit,D21 plugs,tune up
kits,etc? Got the time and retired to work on as
this tractor has many pluses. Thx BC
bill b va
03-10-2003 12:11:23
 Re: Rough Running IH240 Utility in reply to Bill Cole/Rochester NY, 03-09-2003 17:20:04
sounds like you have too much oil in the crankcase .drain some out or change to get it down to where it belongs . too much oil in the crankcase will get too much oil on the cylinder walls and the rings can't handle it . watch oil level if it rises you probably have a bad seal in the hydraulic pump . i had this problem and changed the seal.you may have other problems also .do the tuneup and then check back if you still need help . the blowing gas through carb on # 3 sounds like sticking or out of adjustment #3 intake valve .
Al R in Roch. NY
03-10-2003 05:50:40
I had trouble with my Super A a couple of years ago. It sounds familiar with what you say is happening with your 240. If it sits around a long time, things will show. I first put new wires on and changed the points. After reading some comments on this forum, I checked the air cleaner and made sure that the oil was clean and not over filled. Some "valve medic" in a can was added to the oil. (Majic Beans)! Got tired of changing the # 3 spark plug and purchased another Brand. There was a good debate on the Forum about spark plug problems in Vintage Tractors (Champion vs Other Brands). After several warm ups it now runs good just as it did when I was a boy in the 50's. Good luck, there is plenty of help here.
