Ruff running 240 Utility
Bill Cole/Roche
03-09-2003 21:45:11
Why is it when shut tractor off that antifreeze drips on garage floor and only then?
Enjoy reading the imputes and advice this forum
has to offer. Grew up with Farmalls/olivers down
in Canandaigua. Thx again BC
Randy in NE
03-10-2003 04:09:39
 Re: Ruff running 240 Utility in reply to Bill Cole/Rochester NY, 03-09-2003 21:45:11
Is it dripping out of the radiator overflow? If you have recently topped off the cooling system you could be getting some thermal expansion. After you shut off the tractor the engine will still have a lot of residual heat and the water will continue to expand. There are many other possibilities depending on where it is leaking from. Probably a bad gasket.
