Oil Filter
Avery
03-10-2003 08:45:13
Changed oil in 140 recently. Used Fram oil filter. The Wix filter which I replaced had metal outer casing. Fram filter outer casing was cardoard. Is this filter ok? It's a cartridge type. Anyone use these? Is it as good as the Wix? Thanks.
tbear
03-10-2003 20:09:21
 Re: Oil Filter in reply to Avery, 03-10-2003 08:45:13
Do your self a favor sometime buy the different filters and cut them in two you will see just how bad a fram filter is.I only use napa or wix oil filters myself i'm told wix makes for napa so they are same
klf
03-10-2003 20:22:03
 Re: Re: Oil Filter in reply to tbear, 03-10-2003 20:09:21
I agree with everybody else. I have also found Hastings, AC, Baldwin, and Luberfiner to be very good filters too. MAKE SURE that you only buy NAPA GOLD filters, and not NAPA Silver. The Silver ones blow.
Joe In Va
03-10-2003 10:49:35
I used to work the counter in a parts store and we would not have sold Fram filters. Tons of people use them but they are definitely the bottom of the barrel. The Wix filter is high quality and was preferred by the "car guys" that came into the store. I use them on my 300U.
Steven@nd
03-10-2003 09:19:40
I agree with RAW, have looked at studies of oil filters and Fram is at the bottom of the barrel.
RAW in IA
03-10-2003 08:50:35
Just my oponion, but from what I have read andheard from others, I would not put a Fram filter on anything. The wix is much better filter,
