Wiring diagram
40 H Nate
03-11-2003 16:39:41
HI Guys, wondering if anybody had a wiring diagram handy or could explain wiring for a 40 Farmall H with 6 volt and magneto. Thanks in advance.
Nate
40 H Nate
03-12-2003 16:43:27
 Re: wiring diagram in reply to 40 H Nate, 03-11-2003 16:39:41
Thanks a bunch Guys, information is much appreciated.
Bob M
03-12-2003 07:15:02
Nate - Punch below! Diagram was scanned for an early 40's Farmall A/B manual. Your H should be wired the same.
steve
03-11-2003 19:24:08
i will send you a diagram for a 40s ALLIS. might not be exhactly the same, but similar. it has a mag, 6 volt positive ground, and a cutout relay on the generator. if you have a voltage regulator it will be a little differnt, just ask. a cutout has two wires and the "F" terminal on the generator goes to the light switch. a regulator has 3 wires and the "F" terminal on the generator goes to one of the regulator terminals.
