101 mccormick thrasher
allen carelock
03-14-2003 12:51:14
i have just purchased a 101 thrasher.i dont know anything about this type or model of thrasher.if anybody knows anything about this machine or has any articles that they could pass on,please do so.i would like to read up on this machine and learn a little bit about it.
Harold H
03-14-2003 17:56:01
 Re: 101 mccormick thrasher in reply to allen carelock, 03-14-2003 12:51:14
Allen,
Your McCormick 101 Harvester Thresher was built as the smaller of three sizes self propelled combines along with the 141, 141 Hillside, and 151 combines. It was standard with a 10 ft header. It has a three speed transmission with variable speed belt drive. It has a 27 1/4" x 22" rasp bar cylinder. By changing sprokets the cylinder speed can be varried from 220 to 1265 rpm. It has 3 section straw walkers. The engine is rated 55 hp at 2115 rpm. The grain tank holds 40 bushels. The grain machine weighs 6682 pounds with standard equipment. The 101 was also available in a Rice Field Special model. The rice machine had larger tires, different axles, spike tooth cylinder and other equipment and weighs 7200 pounds with standard equipment. You can probably get a operators manual, possably from your CaseIH dealer.
Harold H
Rich
03-15-2003 08:53:52
 Re: Re: 101 mccormick thrasher in reply to Harold H, 03-14-2003 17:56:01
a owners manual is still avaliable go to your caseIH dealer part# is 1018063r1 for 101& 101 rice machine
