Hugh Mckay Mike Solden
Bill L Md
03-15-2003 17:29:23
check out Farmall daddy's m that won't start I have run out of ideas,need sugestions.
Steve - IN
03-15-2003 23:46:44
 Re: Hugh Mckay Mike Solden in reply to Bill L Md, 03-15-2003 17:29:23
Ditto what Hugh said below. An engine that will lock up the wheels in 4th gear has something inside that is on "press fit" tolerances and doesn't want to turn. I'd guess either a rod or main bearing is real tight -- or a ring is cocked and doesn't want to move up and down. I'd drop the pan and start removing rods then mains until it turns easily.
Steve
