How much oil do I put in the belly pump in a Farmall H
44H
03-16-2003 08:16:37
How much oil do I put in the belly pump on a Farmall H?
Thanks
Farmer Bob
03-16-2003 09:49:47
 Re: How much oil do I put in the belly pump in a Farmall H in reply to 44H, 03-16-2003 08:16:37
6 qts. Hy-Tran or any good quality hydraulic oil. Some even use 30 wt. non detergent oil. If you have other tractors, equipment, or cylinders you should keep the same oil in all equipment so you don't cross contaminate the oils.//FB
fredo
03-16-2003 18:25:08
 Re: Re: How much oil do I put in the belly pump in a Farmall H in reply to Farmer Bob, 03-16-2003 09:49:47
there should have ben a dip stick in it when it was new, check shows this summer you may be able to make a copy of one. [dip stick]
fredo.
fredo
03-16-2003 18:24:17
fredo.
