Super C fast hitch plow
Andrew Tucker
09-09-1999 22:34:21
i have a two bottom fast hitch plow. i use it for garden plowing. i have replaced the points, shares, and moldboards I can't seem to get the rear end to plow as deep as the front. I get this problem no matter how i adjust the right side touch control lever. any ideas???
Curt Cooke
09-10-1999 07:11:04
 Re: Super C fast hitch plow in reply to Andrew Tucker, 09-09-1999 22:34:21
Andy, do you have a set-up manual for that plow? The only thing I can think of is the set-up of the hitch; there are pins to be installed and removed for float of that hitch.
Kim Wm. Jeppesen
09-10-1999 19:31:35
 Re: Re: Super C fast hitch plow in reply to Curt Cooke, 09-10-1999 07:11:04
I also own a fast hitch Super C and plow. I believe the solution is the left touch control. My tractor is 150 miles away right now but if memory serves me the left control is to adjust the tilt of the hitch. This adjusts how level from front to back the plow. You need to have both touch controls hooked up to the plow. One adjusts the tilt of the plow from side to side and the other adjusts the tilt front to back. I remember when plowing last fall that when I raised the plow out of the gound when it was correctly adjust that it was just barely above the ground. I hope this helps.
