706 Injector Pump Install
Brett M
03-22-2003 13:17:38
Greetings! At the risk of showing my complete ignorance, I need help installing my rebuilt injector pump on my 706. The pump came with a tag indicating it is to be installed at TDC on #1 cylinder. I removed the inspection plate, found TDC on the flywheel. I also removed the lifter cover (it was leaking anyway). I rotated the engine one revolution back around to TDC. During this revolution the intake valve (second lifter from the front?) went up and back down. I believe I am ready to install the pump. Any input from those more knowledgable would certainly be welcome.
Thanks to all in advance
Brett M
Jim
03-24-2003 08:03:31
 Re: 706 Injector Pump Install in reply to Brett M, 03-22-2003 13:17:38
You will be on TDC number one when you can turn these six push rods: from the front 1,2,3,5,7, & 9.
Gav-n-Tn
03-22-2003 18:35:06
The number 1 piston has to be on compression stroke to set the time on the pump.Both valves should be closed on number 1 cylinder.Then find the appropriate timing mark.
Brett M
03-23-2003 10:21:14
 Re: Re: 706 Injector Pump Install in reply to Gav-n-Tn, 03-22-2003 18:35:06
I probably did not offer a clear explaination in my previous description. Both valves are closed at TDC but as such could not be certain if I was on the compression cycle. I rotated the engine one revolution, and during that cycle, the intake valve did open and close before returning to TDC. This is the point I have left it believing it is at the proper point for installation of the pump. Does this sound about right?
Thanks for the response,
Brett
Aces
03-22-2003 17:13:36
You did not say which engine you have D282 or D310
Brett M
03-23-2003 10:14:08
 Re: Re: 706 Injector Pump Install in reply to Aces, 03-22-2003 17:13:36
I do not know the engine identification number, however, I have reason to believe the tractor is about a 1963 model and does have glow plugs, and a Roosa Master pump.
K.B.
03-23-2003 12:53:15
 Re: Re: Re: 706 Injector Pump Install in reply to Brett M, 03-23-2003 10:14:08
That's the American-built D-282 since it has glow plugs and a Roosa Master.
