Farmall B
Ben Bole
03-22-2003 20:59:14
I have a B with a stuck engine and badly worn head. I found a 123 engine that was on a baler.
Can that be mounted on my B? I think that Farmall C's had the 123 engine as did the later A's. What kind of problems can I expect?
shaggy
03-22-2003 21:17:33
 Re: Farmall B in reply to Ben Bole, 03-22-2003 20:59:14
Yes it will work but you may have a half moon hole (I think on the right side) if the starter went in from the front. We have used them several times in the past.Good luck.
Ben Bole
03-22-2003 21:38:09
 Re: Re: Farmall B in reply to shaggy, 03-22-2003 21:17:33
Shaggy:
The 123 has a starter that comes in from the front and the original B starter came in from the back. I have to cover the old starter hole on the B and use the 123 flywheel and starter from the front, right? I want to replace the clutch and throwout bearing while the tractor is split.
Any thoughts on this? Are the C and B clutches the same? Thanks for your help. Ben
gene b
03-23-2003 04:19:48
 Re: Re: Re: Farmall B in reply to Ben Bole, 03-22-2003 21:38:09
Use the original starter hole and original starter as the one that comes in from the front turns backward from the original. Also the bell housing will not let you come in from the frontso stay with the original set up when it comes to the starter.
A Guy
03-23-2003 17:37:48
 Re: Re: Re: Re: Farmall B in reply to gene b, 03-23-2003 04:19:48
I whittled out a piece of wood and bolted it into the place on the front where the old starter hole was. With a little bondo and paint on top of that it looks original.
