Grabby clutch in Farmall A
BEL@IN
03-23-2003 13:18:31
My A has the most annoying clutch, even the most careful starts are jerky. I have examined the plate and disc when it was split and they looked fine (probably should have replaced the disc). Sanded off a little glaze and put it back together, still jerks. Even tried holding brakes and slipping it,no help. Thanks in advance to all who would care to comment.
Hugh MacKay
03-23-2003 17:54:13
 Re: Grabby clutch in Farmall A in reply to BEL@IN, 03-23-2003 13:18:31
I gather that this not a new clutch, correct? Is it the heavier clutch with 6 springs in presure plate. My 130 and 140 both had Rockford clutches from new and never seemed to be a problem. However, when I put that same heavy clutch in Super A, I found it was quite vicious when letting clutch pedal out for some time. It has been about 5 years now and is some better. It is still not as smooth as others. The original clutches in Super A's had only 3 springs in presure plate. I have often wondered if the flywheel is somehow not quite right for the heavy clutch? Just a thought.
